NOOB Question
So i have the new 33s on the blazer now and i have been driving it a little more i have had the differential fluid checked in the rear and the place said it was full but the person before me apparently could not get the plug out of the differential so they drilled it and tapped it and put some weird elbow thing on there so im going to have to see about fixing that if possible but the rear end seems to be getting louder as i drive it more so im thinking the rear end is going to either be replaced or re built? what will be my best/ cheaper route rebuilding the one i have or replacing it? axles on cl all the time for between $100-$150 a pair
I will post up some pics of the blazer with the 33s on it and probably the weird plug thing in the rear end also tomorrow
would be interesting to see the plug, sound hooky
take it off and get your finger in there, make sure you can touch fluid without bending your finger down, it should be right up to the bottom of the plug.
yah i will get a pic of it tomorrow and i had it checked and when u loosen the elbow thing fluid runs out so i am pretty sure it is full it is defiantly hokey lol
wowstupid
wowstupid
wowstupid
wowstupid
Here is the pic of the rear end
