so...will a dodge 44 fit the k5? I thought i saw @GWeakland620 had installed one in a build of his. the guy is just about giving it away. this is the axle:
Well, I believe the axle widths are differentso...will a dodge 44 fit the k5? I thought i saw @GWeakland620 had installed one in a build of his. the guy is just about giving it away. this is the axle:
okay, i'll check ord and see.I believe ord has offset leafspring bushings to use that axle.
Mine is a Dodge Dana 60. And I used ORD’s Dodge offset bushings. I don’t know much about the Dodge D44 stuff.so...will a dodge 44 fit the k5? I thought i saw @GWeakland620 had installed one in a build of his. the guy is just about giving it away. this is the axle:
Parts alone worth 150 . Looks like full time 4x4 unit bearing tho .
Yes, spindles and everything out should be same mount. Bolt up everything GM to the dodge knucklesCould you swap GM outers from the ball joints out on a Dodge D44 like that to eliminate the unitized bearing setup ?...
There are a lot more Dodge axles around here than GM's in salvage yards..
