I have a "small" leak coming from the front of the front drive shaft. I initially thought is was trans fluid leaking onto the shaft, running down it and eventually dripping to the ground. However, it does not appear that way (although I can be wrong as I have not fully gone under the truck to investigate yet).
I'm wondering if the tcase has a leak that is running down the shaft. About a month ago I changed trans fluid/filter and wiped down the shaft. Now it is moist again pretty much the entire length, which leads me to believe it is a seal or something around the rear of the shaft.
I have no experience with tcases, so I need to know what kind of fluid/oil I should use, how do I fill it, how do I check the level (which is now probably low if it has been leaking for the past couple months, lol). What is the expected cost for a tcase rebuild as well??
Thanks for your help!
