rpinkstn
Registered Member
total Noob here, just looking for some opions, advice, wisdom...
Finally time to for an axle swap for my '86 K5! I have a bit of a dilema though, I'll do my best to explain...
A while back a good friend of mine (hard core Jeep Rock Crawler guy) talked me into doing some side work for him in exchange for axle parts. From that deal I got:
My dilema is this, I *know* the group wisdom says "Don't bother with a Dana 60 rear! Go with a 14bff!" But I already have all this stuff sitting in my garage! I know I still need, at a minimum:
Goals are a simple, low budget K5 that I can drive on the street, accross a plowed field, throgh a some mud , through the woods and get to some fishing holes and hunting spots. No plans for serious mud bogs or rock crawling. want to be able to take to the trails now and then, but nothing more than a 3 diamond. My engine is a fresh rebuilt low compression 350, trans is a fresh rebuilt 700r4, t-case is the stock 208.
What do you guys think? With cost being a major limitation, should I ditch all the Ford axle parts I already have and jump on this local 14 bolt and go that direction? Or stick with what I have and just get it together and wheel it?
Thanks for reading!
Rob
- '78 Ford F-250 Dana 60 *rear* axle, open diff, supposedly 4.10 gears, minus yoke, minus hard brake lines and minus parking brake cables
- nice brand new Solid Manufacturing diff cover for the D60 rear
- '78 Ford F-250 Dana 44 *front* hubs, spindles, stub-shafts, knuckles caliper brackets and calipers
- GM 4.10 ring and pinion and open carrier for a corporate 10-bolt front axle
- new spring perches for the D60 (loose in box)
- new shock mounts for the D60 (loose in box)
- new rear axle u-bolts and nuts for the D60
- new brake pads and shoes (front and rear)
- new bearings and seals for the D60 rear and D44 front components
- locker for the D60 rear (I think I've found one for cheap on C-list!)
- new (or used) yoke, yoke seal and yoke nut for the D60 rear
- new hard brake lines for the D60 rear
- new parking brake cables for the D60 rear
- some means of connecting or adapting the Ford style parking brake cables to the GM parking brake cable
- ??? not sure what else
Thanks for reading!
Rob
