Normal Driveline Angle?
PsRumors
Cartersville, GA
What is the normal (stock) driveline angle for the engine, transmission and transfercase?
I am finishing up a 4l80 205 install and used a crossmember out of an '84 back truck and the TC adapter is an Advance Adapters tall adapter.
I ended up with about a 7 degree incline. I can move the crossmember to on top of the bottom frame rail and get to about 3 degrees. If I do that I will have to re-shim the rear axle.
Thoughts?
