"normal" knock sensor counts.......
coyle13
Albuquerque, NM
\"normal\" knock sensor counts.......
I am trying to track down an intermittant loss of torque and power, and I think I have it narrowed down to the ESC system. I have an Autoxray scanner and was wondering what are the "normal" values associated with spark knock count? /forums/images/graemlins/thumb.gif
Re: \"normal\" knock sensor counts.......
I think your not supposed to have a knock signal for more than 5 seconds. It is normal to have a knock, and the computer will even set a code for no knock signal at WOT. Well CK5 erased the educational post I had only a month ago on this subject with a plethera of info, we'll just have to repeat ourselves more.
i don't know about normal knock counts.. but I was getting a detonation sensor error... and i could feel the engine wasn't running right, some lack of power...
Well i found the cause was the wire going down to the knock sensor rubbed up against the headers and melted the insulation, shorting the knock sensor wire... This threw the code and pulled a lot of timing out of the engine.
