Just bought a stock 88 k5 blazer(v10), 350 tbi, about two weeks ago. At that time it had two leaks,(power steering and LITTLE coolant on starter) until I took it to the car wash to wash of all the mud and oil build up it had underneath. Then a new leak appeared, motor oil. I went ahead and did a semi tune-up; air filter, fuel filter, motor oil(10w40) & filter, plugs & wires, and pcv valve. When I went to autozone to get the motor oil, I was recommended to put in 10w40 valvoline instead of the sae30 penzoil I was thinking of. The oil pressure gauge had not been working correctly since I got it. At first after running it for more than thirty minutes it would drop from 30 to 0. Oil level was fine, power seems good, radiator is still full. Since the oil was leaking from oil pressure switch (unit), I replaced it with a new one from autozone. Now it reads 60 when I start it and goes down to 45 when I put it in drive. When I drive it goes from 40 to 60 depending on mph, and when I put it in park it will go to 30. I dont have a tachometer yet.
Sorry for the long story. I want to replace my power steering pump because of the mess its making on the driveway. But not sure how big of a deal this oil pressure situation is. The coolant leak is more of a drip on the starter and does not make it to the ground. I've tried checking underneath with flashlight, but don't see where it's coming from. I will be dropping the starter this weekend, (family time permits) hopefully to get a better look. I've driven it about 250 miles, some highway and some city. And the radiator is still full to top from previous owner. Exahust spits out white smoke if I give it gas when in park, and it smells like strong gas fumes.
Thanks in advance for any help.
