Normal Oil Pressure?
Chief Brody
"Amity Island Welcomes You"
Alabama
What is normal oil pressure for a 350 on the manual oil pressure gauge?
What is the value of those three big white lines? 20/40/60 ???
So anywhere between the last two marks is good when cold?
I wasn't sure...didn't know how to read it and they didn't put a "warning" sector on it...it likes to stay over by the 3/4 area....I thought it might be high because that doesn't leave much headroom...
I have revved it up high and it approached the 60 mark but never quite gets there...
guess I figured "middle of a gauge is good" and it wasn't ever there either
Well that too. :D If the gauge ever reads more than the 60psi max on the gauge then I would be looking for the reason.
I wouldnt worry if it pegged..... As long as it was high RPM. My 350 will hit 80 at about 5500rpm.
As long as it comes back, i wouldnt worry. Just basically confirms the gauge is working.
Also, below 30 seems high. I think the manual says 15 or so at idle for the lowest.
I should have clarified that I meant if it pegged and stayed there then check to find out why.
