Several years ago the CDR went bad, or at least I thought, on my truck allowing engine oil blow-by into the intake. At the time I couldn't find a replacement so I swapped in a standard valve cover breather/oil seperator with a hose running down to the frame area.
Since then I've always had issues with blowing oil out of this breather, but not horrid, and some smoke coming out of it. If you sit with the engine idling I can see some light smoke (or some type of vapor) coming out of the end of the hose.
Is this normal? I always racked it up to just being a trait of the 6.2 and not having the enclosed CDR system on it. I'm concerned that maybe it's a sign of engine issues.
It's mainly an off-road rig and gets trailered so not a whole lot of miles put on it but it will probably run at least 6 hours non-stop on the trail when I do take it. It appears to run perfectly normal with no obvious power loss and doesn't get hot or anything even during sustained WOT operation (like trying to get out of a mud hole or up a slippery hill), and I haven't noticed any coolant in the oil or vice versa.
