If it won't stay charged, then you have a draw on the battery thats not supposed to be there. lets see if I can explain how to find this
1.pull all fuses, ALL of them!
2.remove the positive battery terminal from the battery, and hook up your voltmeter inbetween the terminal end and the battery post.
3.start installing fuses one at a time, all the time watching the voltmeter, you should see a momentary surge in some circuts then back to zero, IF, you get a fuse in that pulls a constant voltage, then you've found you problem area.
4. now, if you don't find a draw on the system, now it's time to check the alternator itself for a draw.
5.turn off everything in the vehicle, pull the largest wire off the back of the alternator, install the leads of the voltmeter between that wire end and the attach point for that wire, there should be no power flowing through that circut. if there is the diodes are bad in the alternator, replace alternator.
6.If none of this works then only one thing left. Get a stronger alternator.
Don't be shy about asking a ??? I'm pretty good with this kinda thang!
