mudbog42
Well it all started when having to replace my intake gasket on my 86 K-5 w/ a 350
Got it all back together and now she won't stay running
if the RPM's drop below 2000, it will just stumble and die.
Also it seems to be leaking from the drivers side intake bolt second one back from the front
, can I just pull that bolt and put rtv on it or what is the deal with that
So far I have done the following to troubleshoot:
-Checked firing order multiple times
-Brought motor to TDC to be sure the rotor was pointing to the #1 Cylinder, it was pointing directly at it
-Had the distributor marked in 3 different places just to make sure it back in the same spot and all my marking line up, Dizzy dropped right into place when installed
-Checked vacuum lines multiple times and can't find any disconnected
-Looked at vacuum schematic under hood and all lines look to be in the right places
-Can't keep it running long enough to confirm timing, but have tried moving the dizzy around some to find a good spot to keep her running, no luck
At this point I am at a loss, I am supposed to go camping this weekend, but it is not looking so good now as my truck won't work right.
Any help would be greatly greatly appreciated
guess I'll have to pull it back off, I did tighten them in sequence though BTW
