Kain
3/4 ton status
I know the dizzy is not spinning that the clamp down is tight but it loses its timing it is out of time again.
the reason i know is i marked the body of the dizzy on the intake and my marks have not moved.
it is an hei dizzy. I replaced everything in it the wire to and out of the module, the module, coil, cap and rotor new wires and plugs when i changed manifolds. What would cause this?
do i put another in in summits hei are not that expensive. cant afford msd and fitech dont like em anyway.
https://www.summitracing.com/parts/sum-850001r
I would need a curve kit but would work and i would have spare parts all the crap in the one thats in there is new........https://www.summitracing.com/parts/sum-g5212
