COCHEV
Installed it yesterday on my burb. it is true plug an play as i've read on here (which is why i bought it) However, the harness is not long enough to run parallel with the factory harness- which would have made for a much cleaner install. And the ground leads on both sides are just shy of being long enough to tie into the factory grounds on the core support-again, would have made for a much cleaner istall. Further, the two positive leads pulled out of the drivers side plug just routing the wires around- not pulling on anything hard what so ever.
just thought i'd share my 2 cents on this. i think i will eventually just make my own setup.
