Not starting or staying on without gas pedal pressed
Just did all of the above. Replaced a bad spraying injector but still hesitates. Gonna play with the timing next.
So I'm having basically the same problem, my truck will start and run fine for about 2 minutes, and will stall, it will fire right back up and only run for less and less time every timeffort, changed the ignition control module and that hasn't helped, fuel is spreading out of injectors perfectly, but still cuts out, before this it would cut out when I hit the brakes too hard or from being too hot, I'm at a loss for advice and can't fix this darn thin
Any luck on solutions? I'm having the same issues and I'm having a similar ineffective results by just swapping parts.
