Bone stock. 45k on new GM engine. 102k on truck.
This does not happen during cold idle.
If I hold the throttle just off idle, it sounds like a big block on alcohol. Durring exceleration and deceleration it is fine. Running at fwy speeds it is fine. But if I run it just a crack open, it lopes. Has never died. No black smoke that can be seen. If I open it up a hair more or completely back off, it goes away.
I changed the TPS and checked the timing. TPS was no change and timing is right on.
