Np 203 / 205 Doubler Truss
Copperhead Fab
Registered Member
Lubbock Tx
http://copperheadfab.com/index.php?action=productview&productid=226
Truss is designed to take stress that is put on the adapter between the NP 203 and NP 205 and transfer that stress to the cross member. It also allows room to weld bushings for cross member in a verity of locations (bushing not included). Comes with bottom plate, PTO cover, and three gussets to tie everything together. Brackets do not come welded.
so does this work with pretty much all Doubler kits, or just the... NWF? in the pic?
I think it's a great idea, btw.
It will work with any doubler kit that has a 3" wide adapter assuming that you have the exact rotation that this kit was built for otherwise you'll need to modify his brackets to fit a different rotation before welding.
Guys, don't expect an answer from him anytime soon, he's not a good people person as you can tell.
I think i PM the first poster about buying the plate separate the day he posted it.
Yes you can buy the bottom plate separate, please call us at 806 392 5390.
Its set up to work on a 205 that has rotation flat. i think we used it on a rotation of 2 degrees with no problems.
I never got that pm :confused:, anyway I'm still interested. I will give a call tomarrow. Could you give me an overall dimension on the plate so I can see if it will work with what I'm planning on doing with it?
