@kennyw the big stainless tag looks to be the hydro pump info . not the pto info . then that aluminum little tag is the np205 build tag . if the price is right i might go for this as i just got a pto ramsey winch and could maybe convert it to hydro winch but the pump might not be the right spec who knows yet until one of us does some digging . but then we need to know the pto output ratio to know the pumps input rpm to calculate the flow .
looks like the pump # is good . what is the width of the middle section of the pump ? not the end sections . as the gears for the pump = flow rate and this pump could be built with around 6 sets of thickness gears . between the black lines on your pic i just edited .
were looking for a tag on just the pto unit for its specs . judging by its layers of slime it might be under all of it . but dont get to crazy cleaning some tags can be wipped off of info to easy . the good ones are stamped in .
