np-205 32 spline in/out with twin stick mod
sweetk30
Back to play nice .
in the back of your brain
NO LONGER FOR SALE : USED IN PROJECT TRUCK.
I have a figure 8 32 spline short input 205 I just assembled .
specs:
n.o.s large bearing input 205 case
brand new ord 32 short input/bearing/retainer ring's
full gasket / seal kit
good guts from a low mile 205 I don't think was hardly ever in 4wd
32 spline front output shaft swapped in
208 flat c/v flange on front output with correct seal x2 doubled up
modified shift rail for full twin stick function
fixed yoke rear output / red speedo gear
figure 8 th400/205 gm adaptor
this unit was cleaned / reused all bearings from low mile case I took guts from . all new gaskets were installed and seals .
assembled needle bearings with assembly goo grease just for this use .
just needs your rear yoke installed / fill with oil .
bench tested good and snug no major play . twin stick functions as it should .
