- Joined
- Mar 3, 2000
- Posts
- 9,124
- Reaction score
- 7,078
Ok so I followed all the instructions on how to remove and re-install the shift rails, and I learned how to get the shift forks back in position after the allen wrenches fall out of place.
So I install the front shift rail per instructions, then move to the rear. When re-installing the rear shift rail the detent ball on the side will spin but not move inward so the rail will only go as far as the end of ground part of the rail and then the detent ball on the side wont let the rail go in any further.
I have lubricated the ball and it spins but doesn't push in at all. Is there a way to get it to loosen up or do I just need to apply some pressure to get it past?
I noticed the old rail had a pretty good mark from the ball.
Thanks
Thanks
