trevmountain
I am in the process of swapping over my slip yoke 205 to a fixed yoke from a donor NP 205. I couldn't see how to just swap the shafts themselves and so I pulled the entire unit out. In the process all these little cylinders fell out. It's on the inside of the case where the gears mate up inside the transfer case.
You can see in the pics the old slip yoke is on the left and the new fixed yoke is on the right. For the life of me I can't figure out how these can be set into the cylinder and stay in place long enough to slide it onto the inner shaft. You can see that I started to set them into the cylinder in one of the pics....
Help
Help
the first time.
