np 205rear output flange ?
notsosanestan
Registered Member
New Jersey
i tried to search for this but came up with nothing. i was wondering if i can convert the rear slip shaft on my 205 to a flange style
just need the fixed yoke shaft and seal retainer. then swap your slip shaft for fixed on tcase. then get a flange from a supplyer like high angle driveline or others. then get your new shaft to bolt to the flange and axle yoke and your done.
edit : start at post #22 http://coloradok5.com/forums/showthread.php?t=253000 for the pics and step by step on installing a rear shaft on a 205. otherwise its a full writeup on reman of a 203 range box and full 205 reman and doubler kit after.
