Wanted NP 208 whole shifter assy
80 Chevy K20 4x4
Athena, OR
Also, it looks like the previous owner installed a NP 208 t-case, and I want to find the shifter bezel, boot, whole assembly for it.
I'm needing just the left side part of the fuel cap bedside piece so I can graft it into my SWB for adding a dual tank.
Also, it looks like the previous owner installed a NP 208 t-case, and I want to find the shifter bezel and boot for it.
I'm sold out at the moment, but this is the whole NP208 shifter assembly you are looking for. Plus a rod between the shifter and tcase lever.
kenny,
How much do you usually charge for this complete setup?
I know my transfer case lever is connected to the transfer case, but it doesn't have the shifter bezel and boot. I'll look at it more closely this afternoon after I get home from work.
Kenny,
Also, I need the intermediate steering column shaft for the DD coupling for the 78 tilt column my friend gave me.
Please let me know.
Thanks!
I have several of those. $30 shipped.
The intermediate shaft correct from column to the rag joint?
If so, I'll take one!
As soon as you find a complete NP 208 shifter bezel, boot, shifter lever, shift know, linkage rod, just let me know and I can send you the funds altogether.
Thank you sir!
Thank you sir!
I have a couple shifters for np208
