Wish I had a camera and could post a photo of the NP-246 saw that a friend replaced the other day,after I helped him locate the source of a strange scraping grinding and clunking noise by putting it up on his lift and me getting in and putting it in drive and racing up the engine--driving the truck,it felt like the rear diff was junk,but it was the transfer case making the noises.................................................................................................He tells the owner the T-case is fubared probably,it had over 200K on the truck,so it was likely toast--salvage yard wanted 900 bucks for a used one with 90K on it,so he decided to buy it,rather than spend 1600 at Autozone to get a rebuilt one,or 2K at a dealer for a GM Goodwrench one...........................................................................................................................................................................................................My friend showed me the blown up one yesterday,I got there just as he was about to put the "new" one in...all around the case after the input shaft about 6" back,there was a slot cut right thru the case,about 3/4 of the way around!
..another few miles,I bet it would have sawed itself right in two,and dropped to the pavement!..the owner had been commuting 50+ miles to Boston daily in it too,right up until yesterday!...guess you cant say GM's aren't dependable,even when they are ready to come apart!--weird thing was,we saw no evidence of lube splattered under the truck,all that came out of it was metal filings that looked like brake lathe dust!...and the peices inside that did the cutting looked like large shims or clutch packs like a automatic tranny has...it must have been empty a long time!...
..I'll see if I can get someone else to snap a photo before he scraps it--its not that impessive as carnage goes,looks like someone was inside it cutting their way out with a hacksaw blade,a nice thin slot!...maybe we should have test driven it longer,till it sawed itsef in two...
