Found NP203 Boot Ring
Shawn
Nuckin Futz!
Author
5280'
Looking for a NP203 shift boot ring like this one below. Don't need the boot, just the ring black trim ring.
I have these, boot ring and selection indicator plate. Let me look tomorrow so Im sure what I have will post up some picks
The boot.
This is the top ring that goes over the boot and is seen from the top.
This is the bottom ring that holds the boot down.
Set backwards.
Here is a shifter, boot, retainer, and the shift pattern plate.
Boot and pattern without the retainer.
Martin
The boot.
Set backwards.
Martin
Thanks Martin! I can't believe you all those trim rings. I messaged you.
I have a good trim ring and shift pattern plate for $30 shipped.
Thanks! I think one of Martins might work. I just need to the ring to cover the larger carpet hole which was cut for the NP203. I don't have NP203 anymore, has a NP205 twin stick so the shift pattern plate wouldnt work for me.
I did, thank you. It was not necessary. I meant to message you that, but forgot.
Martin
