np203 front driveshaft
michael0584
houston texas
I need a front drive shaft for a np203 transfer case. CV style in 26-28 in. Range. Let me know if anyone has any laying around.
ahh forgot will do it this weekend. wife is prego and running me ragged 18 days to go !!!:bow:
I've got 2 different style output yokes. One is the 4 bolt flange and the other is the ujoint cradle.
iirc, the spline counts for yoke style are different then the plate style, they dont interchange. Output shafts would have to be swapped over, major pita.
Which drive shaft do you have the 1976 down or the 1977 up which is the flat plate type driveshaft. I have 3 1976 down front driveshafts that are off of 350/203 combos and 1 400/ 203 combo. I am close to houston during the week when I am in Conroe.
bigred81
I've got 2 different style output yokes. One is the flat plate, the other is the half ujoint cradle. I'm assuming thats the style you have. I really have no preference on which style. Do you know the length? I live in spring so Conroe is really close. How much do you want for it?
The front driveshaft from the 400/203 combo is 29 inches fully compressed and 32 inches fully extended. The 350/203 drive shafts will check later today when I am at the shop getting parts for my truck. I would like to get $65 for the front drive shaft. All of my front drive shafts are for the early style u-joint cradle.
bigred81
