Ok, i am getting a parts list together for everything i am wanting to do to my blazer.
first order of business is to remove engine and transmission. Overhaul engine has a crate engine 350 and would be shooting to around 450hp, so ill be getting alum heads, cam and probably punch it out a little. will be using Holley efi sniper system as well.
I will be getting rid of the TH350 tranny and replace with a B&M 700r4 with around a 1500 stall.
while all this is out i would like to switch to 2 stick shifter and put a part time kit in the transfer case.
After reading people prefer to go through the transfer case and install the complete tailshaft for the part time kit.
I am having trouble finding a kit with the tailshaft, all i see is just the spider kit im guessing is what it is.
can someone point me in the right direction.
also will be completely redoing both axels and going to 4.56 ring and pinions with the overdrive tranny.
