well guys I think the 203 in my blazer is on its way out. Here's what is going on. When I accelerate off of a stop I have to accelerate very slowly because of you gas it hard you get clunking, almost like the t case chain/gears are slipping, and also when your going uphill when it's under a load it makes a grinding noise almost like a groan and when it groans you can feel it in the shifters for the t case. If all of this is coming from the tcase there should be metal shavings in the fluid right? I'm gonna check on that ASAP. What do you guys think is going on? I appreciate any and all answers I can get. Thanks yall.
PS: here is the parts I have personally replaced recently.
U joints front and rear shafts.
Tranny rebuild (2000 miles ago)
Tranny mounts
And the parts I have laying on my workbench that need to go In:
Rear leaf spring and shackle bushings
U bolts
Rear pinion seal
Tranny mounts
U bolts
Rear pinion seal
