np203 questions & lift questions
h0nke
Firth, ID
my 73 truck has an np203 with a part-time kit in it. should i stick with this or install a np205? ive got a th350 tranny that was just overhauled not to long ago.
i have 6" skyjacker kit with rear blocks. should i upgrade to rear springs? i have a dual shock kit im going to install soon and i want to put a 14bolt soon too (im not sure if you need HD springs for 14bolt?).
thanks yall
If the 203 is already part-time then I'd say run it until it gives you problems. From what I understand you will need to occasionally (every 300 miles or so) drive with the hubs locked to lube the chain. Otherwise the only thing you'll get out of the 205 is a little better strength. Crawl I believe is pretty darn close on both. 205=1.96:1 vs. 203=2:1. Someone please correct me if I am wrong.
As for the blocks... I think you'll find the general consensus will be to lose them. Either springs or shackle flip or combo of both...
