cegusman
3/4 ton status
Any one completely dissemble a np203 range box? I want to get the case sand blasted before I put my doubler together so it needs to come apart.
I haveAny one completely dissemble a np203 range box? I want to get the case sand blasted before I put my doubler together so it needs to come apart.
Well I'd say it would be pretty easy for you since you have some t-case experience. Before I did my 203 I had only dissasembled/reassembled a np-241 in a college class several years ago. Do a google image search for "exploded diagram np-203" That will come in handy.Is it pretty easy? I have rebuilt a np205 and many np208's so I am not a newb. Is there anything I should know before I tear it apart?
Oh it isGot the idler shaft out. Looks like some fun putting all of those needle bearings back in.
Don't be afraid to use some grease
Patience is a must, the needle bearings didn't give me any trouble. It was those shims on the front and rear of the idler shaft that sucked, they kept falling down when I was installing the shaft
That don't happen if you have the case on it's front or back side when installing the idler shaft and all the pieces.![]()
Now you tell me!Now you tell me!
You should know by now that i usually have an answer for just about everything mechanical.![]()
Yes, but on the day after it is needed![]()
Already got her to rebuild my dana 60
.Ever consider going on that show "Wife Swap"?This weekend I am going to make the wife rebuild the np205 with my supervision.Already got her to rebuild my dana 60
Just a question.
