Np203 shaft eplacement partime question
84400
Registered Member
Northern MA
I have been reading up on this for a while. I got a use shaft replacement kit a while back and just bought some front locking hubs so I am ready to go.
I have read a few write ups online but have Not been able to find a PDF install directions or parts list from Mile marker. The shaft has no markings so I can't be 100% it is the mile marker kit but chances are it is ether the MM kit or by doug nash.
So my question is about what all the kit came with? I am guessing the shaft itself, the gasket (I will make out of gasket paper Thickness?), some end-play shims (which I should not need), and a set of locking hubs (which i have. After reading the write up on coloadoK5 It mentions a "A bearing is used to keep the spacing correct for the output shaft." This thrust bearing as they call it goes between the T case cog and the shaft base. Is this Bearing already in my T case or something I need to find a part number for and order?
I have repeatedly tried to call and email mile marker with no luck. I know it is a long shot but maybe someone on here has installed a shaft part time kit on a 203......
