I have an '83 Jimmy with TH350 and NP203 Transfer case. haven't had the truck long and bought at an auction so I don't have much history on it. Lots of minor leaks from the transfer case, but recently the front output shaft seal went out and it will drain a couple quarts over night. I have a complete seal and gasket kit for the case but was just going to replace the front seal for now. Of course I can't for the life of me get the nut off. Did heat and oil with breaker bar and extension and hydraulic floor jack and it won't budge, just starting to strip it.
Regardless, debating options - do I still just try and do this seal, or pull the case out of the truck and have it rebuilt. I don't really have the confidence to completely split the case by myself and do the full rebuild, never been into one , but I also don't know if it would be worth it to pay someone to do it? Might be more cost effective to just purchase a re-manufactured one?
And if I purchased a re-manufactured one is the 203 they way to go or should I look for a different model? All the transmission adaptors, driveshaft lengths and yokes overwhelm me... not sure what to do, any info would be appreciated.
