JeremiahAB03
Registered Member
I bought 1978 C10 a couple months ago, and I have always wanted a 4x4 but have not been able to afford one. I figured I'm young and stupid, so I will attempt a 4x4 conversion on this truck.
I picked out a 1975 K10 Heavy half frame, no real rust or rot for about 250 bucks. It has a TH350 and an NP203 t-case. I should have thought to check before dropping the engine and cab in place, but like I stated before, I'm young and stupid and figured all would be well.
I got the engine running, which took a while due to some wiring gremlins, and general shenanigans. Went to put the trans in gear and I got this terrible whirring/grinding noise. Didn't matter what gear the t-case was in, and didn't matter what gear the trans was in, besides neutral and park of course. So I fired it back up and left it in gear, so it was making the grinding noise, and I laid down underneath the truck and was listening around the trans and t-case, and was able to discern that it was 100% coming from the t-case.
Started pulling the 203 apart, starting with the driver side "inspection cover". Everything in there looked clean and operable at the least, so I moved to remove the lower drain cover on the passenger side. There lay my problem, the drive chain wasn't even attached to either of the large gears. It seems that it broke clean in half, not sure when or how or why. So I dropped the rear driveshaft, removed the tailshaft and found that the spider-gear housing had been broken as well, likely when the chain first gave way.
So my options are to rebuild the one I have, which seems like it just needs a new chain and spider gear set. Or I can buy a used NP203 off of marketplace or ebay. Lastly, I've heard a lot about swapping to the 205 case, but it seems that the 205 swap is a bit more costly to do. What is the best course of action here?
