DizturbedOne
77 Jimmy 4x4 w/SB400/TH350/NP203 - Should I just swap in a 205 now?
Edit - Well nevermind about that. Got the linkage adjusted enough to get it into the all 3 detents and figured out the P.O. moved the shift plate forwards a bunch and turned the stick backwards so it made it look like the truck was in Hi the whole time (people are such thieving bastards these days I swear). I still don't know if it's converted or not but I don't care anymore as I'm pretty sure the T-Case is dusted inside since I can get it into the Hi detent and all I get is light grinding like something is partially touching.
It really pisses me off because I should have paid 1000 bucks less for this truck already, and now this... But anyways...
So the thread has changed to... What T-Case should I swap to???
