Reasons to frown on a np203. Its as big as a 203/205 doubler, weighs a ton, full time unless you convert it, has a funky stock shifter, and the low range is only 2:1 vs the np 208's 2.61:1. Im running a 203 with MM shaft replacement kit and ORD twin stick, and I havent realy had any problems minus needing another crossmember. with the twin stick and conversion kit i have 4wd hi and lo and 2wd hi and lo. With all of that its a pretty stout case and I cant complain besides it being a monster, but it will do till I get everything ready for a doubler. I agree with 4x4high, you will be set for a doubler down the road
