green
Newbie
A friend of mine e-mailed me a photo of a divorced np205 with 2 rear outputs. for a minute I thought it was a doctored pic. What type of vehicle or application would call for 2 rear outputs?
Think about what you're saying....
If it was truly a "dual rear output divorced case 205" the thing would have FOUR yokes!![]()
A divorced NP205 has two yokes on the "front" side of the case. One attached to the transmission via a driveshaft (that's what makes it "divorced"), and one going to the front axle.
Maybe you were simply looking at the front side of the case?![]()
I think the rear outputs always turn together, so it's not for a PTO. The best application I can think of is a 6x6. You could also use the second output for nothing other than a driveline brake.Maybe the rear output is to hook up to a hydraulic pump.This would be used to operate the winch hydraulics on a wrecker.
Thats what the 2nd rear output on the np200 is used for (in a Dodge M-37 or Kaiser M-715)I think the rear outputs always turn together, so it's not for a PTO. The best application I can think of is a 6x6. You could also use the second output for nothing other than a driveline brake.
