Np205 27 spline coupler
Recon 78
Just got my new 27 spline coupler from advance adapters
27 sp both sides to mate with th350
Original had a snap ring in the middle, this one does not.
It has 2 large grooves and a rib
Does this design omit the ring?
Only thing that snap ring does it “center” the spud on the shafts. If you have 2 correct sized snap rings, I’d add them personally
The grooves are very wide and dont look like snap ring grooves
Yeah, im thinkin that center rib is like the ring
Splines can't pass it cuz it's solid
Just wanted to check on here cuz I'm a tcase swap noob:D
Thank you
