Sold NP205 27-Spline W/Adapter & X-Member
MAXMAN
Wenatchee,Washington
I have a good working 27 spline input NP205 transfer case with adapter plate and crossmember. This transfer case is for use behind a TH350 transmission, or can be used behind a 700R4 transmission with a custom spacer available from Advance Adapters ($90). $350
Honestly, you got me thinking! I know the guys that built the rig this was out of and when they called me I asked the same question. But now you have me wondering the same thing. I need to check with them to see if they actually put a custom shaft in the case. I'm guessing not, but I want to confirm so I can update ad. I've had it quite a while thinking I would use it behind another 700r4, but did not think about tha Advance Adapters shaft for the trans. I rarely ever mess with the lighter duty stuff, and appreciate you bringing that to my attention.
Thanks to imiceman44 for making me double check my post!! I have updated title and price!
I have that spacer new still in the packaging from summit.
I ended up changing the output shaft on my 700r4.
So if someone wants this transfer case for a 700r4 hit me up.
