NP205 32-spline yoke
dremu
Officious Thread Derailer
East of San Francisco
32-spline 1310 NON-CV yoke, suitable for NON-CV front output on a 32-spline on a NP205 with, duh, a 32-spline Ford/Dodge type front. Or on most any NP205 rear, if you so desired.
(as seen on right in pic below; flange on left is sold.)
The yoke is sorta weird. You'd use it for a NON-CV front driveshaft; again, CV's are different! (as I discovered the hard way.) Did I mention it's not for CV driveshafts? :D It will accept a regular 1310 U-joint and plugs onto a 32-spline output, as discussed above.
If you want dimensions, it's remarkably similar to this guy
http://www.dennysdriveshaft.com/p23...spline_np203_and_205_transfer_case_neapc.html
"Good used", no burrs or whatever. $30 shipped. If you're gonna use it on an NP205 it'll include a matching seal (as pictured) because there's different shaft sizes (again, as I discovered the hard way.)
It may fit other t-cases or applications, but I only know about the NP205 'cuz that's what I have. I can measure these for you, but do your research first so you don't end up with the wrong things like me =))
PM me or email dremu-at-yahoo with interest or questions as I don't always follow the threads. Paypal preferred, shipped USPS Priority or Fedex Ground depending on where you are.
Also note that with your purchase you generally receive random free gifts, which may or may not have value to you, but if not, you get to pass on to the next guy :deal: It's my way of cleaning up my garage :haha:
-- A
