Np205/700r4 ???
K5engineer
Monroe/Charlotte NC
I was wondering what I would need to do to mate a NP205 to a 700R4. In my Jimmy, there is now a 327ci/TH350/NP205 setup. I am going with 5.13 gears in my axles and thought the overdrive in a 700R4 would help out when I had the rig on the street. Any help/suggestions is greatly appreciated. Thanks. Tyler
You need to buy the spacer then use your exsiting T-case adapter and T-case. You will need to buy a lock up wiring kit for the tranny, modify the drivelines and also buy a TV bracket for your carb. You will also need to move your crossmember back slightly.
