Hey after doin alot of work to my 78k5 i need a new drive shaft built.i was running a conversion u joint on my last drive shaft because the 14bff is 1350 and the 205 is 1310.so anyways i would like to change the yoke at the case to match the rear ,because i would not spend the money to have a driveline made and still have to use a conversion u joint....so the question is.is it as simple as ordering a 1350 yoke and unbolting the old one and installing the new one?any knida preload or tourque?i should know this but i dont.id appreciate some gelp its thr last step before i can go wheelin besides new shock hoops .
