Np205 for th350...worth buying?
BIGRIG
Independence, MO
Stephen,
I've got a chance to buy a 205 for a t350, and noticed on your site that you only make the doubler for t400. Can the shafts be converted or will yall end up making one for the t350 version. the price with the driveshaft out of a 3/4 ton is $150? Worth it or not? Thanx!
Chris Clay
MY DRINKING TEAM HAS A FOUR WHEELING PROBLEM!
If the 205 is a fixed yoke, jump on it. I'd probably pass on a slip yoke.
1986 K10 TPI350/NV4500/Gen2 Doubler/D60(ARB)/14FF(Detroit)/4.56 gears
BUY! if it's in good condition, it's worth it. Make sure you get the adapter housing to bolt it to a TH350 and the drivesleeve that couples the shafts. Those parts are almost worth more than the case!
We do have the conversion parts, it's about $250 usually to do it. Check the "205 tech info" link on our home page, it'll have some of the info you're looking for.
The Th350 version Doubler is going to be a while, we have a couple of other projects that are taking the front burner at this point.
Making the world better, one truck at a time.
SW-ORD
<a target="_blank" href=http://www.offroaddesign.com>www.offroaddesign.com</a>
