NP205 Output shaft tolerances
folkenheath
Volcano Manifolds
Vendor
Author
Wisconsin
I have been searching all over for this and can't seem to find the answer yet. Does anyone know the endplay and also the radial play tolerance for the NP205 rear output shaft when installed? I am trying to figure out how wore mine is and I can't find this info.
Thank you.
The 205 endplay specs. are .002-.027, theres not really a given number for radial play.Use your own judgement,if the output is really wobbling around there you might want to investigate why.
Rear endplay can vary between different 205s and for the most part is not really adjustable.
Thank you very much. I removed the flange and did some more measuring, and everything looks fine I think. My endplay is on teh high side but I can't complain since it's 28 years old and still going strong. I think I will rebuild the thing in a year or so just so it's like new again.
Thanks again.
