Found NP205 Shifter/Linkage
Is there some reason not to go immediately to twin stick? They arnt that expensive and are MASSIVELY better than stock shifters
My reason is that I'm not going to keep it! I was just trying to make the combination whole to increase the chances of selling it. I have no use whatsoever for a manual trans, just bought an 86 K30 cab an chassis to part.
I have a few I can get you some pictures and tell me which one works for you.
It's different angles mostly.
I won't need it if you buy that cab & chassis!:pimp:
Well I am tempted but it will take a lot for me to get it.
I have 4 vehicles I need to get rid of before I get it.
I have the engine for it so I'm tempted for that reason.
I know how it is! I just sold an M1008, my spare FJ40 is going on Saturday, and I'm bringing another M1008 home from my lake place this weekend to get ready to sell. I will keep in touch with you regarding the shifter though, Thanks again!
This looks to be early 80's figure 8 mechanical clutch setup. The link is there, but no bolt or lever.
$25.00 plus shipping. I might have the special mounting bolt also. If I do I will include it at no charge.
That appears to be the 400/205 shifter but it also works for the 85-91 K/V30's with a 465 and round 6 bolt pattern 205.
This shifter won't work on the 84 and older 465/205 combo's as those shifters are more straighter and compatible with the 350/205 shifter.
I have another that is still on a 465/205 combo at work. I will post up a pic tomorrow.
I’ve used the same stick and linkage on a 4spd and 400 combos (both figure 8 style).
