About sick of mine rattling. It's got the right parts, (except the newer boot isn't tight) and it's a '91. Wear shouldn't be an issue.
I read past threads I could find on the topic, but didn't really seem like any viable fixes for me. Some people it sounds like have shifter issues relating to the shifter bore being the problem, but I'm not sure if that's the direction to head to cure this issue. The earlier shifters are just metal on metal for the pivot bolt, which would obviously make all kinds of noise without lube. On the later ones, like mine, I'm pretty certain the bore is actually already bushed with rubber.
I've tried additional washers, but anything that presses the shifter to the shifter pivot bolt head or adapter means the bolt works loose when you shift the transfercase.
I've tried a large diameter rubber washer that is pretty thin, but same problem. The bolt hits the shoulder and bottoms out, anything that flattens out the wave washer is "too much".
Just thought about cutting a Teflon "washer" for the non- wave washer side...same stuff used on the leaf spring packs. If I used that, I could simply cut a very small piece and affix it to the threaded end of the pivot bolt so that it bottomed out exactly the right depth to compensate for the added thickness on the bolt head end. It's not like it would cost anything, except the hassle of pulling the shifter apart enough to try it.
Another solution might be to find some flanged nylon bushings, and likely machine the shifter handle to accept them. But that's a lot of work if something simpler will work.
Just soliciting ideas/thoughts I suppose. I can't stand constant noise like this which I know can be stopped, and is just asking for me to figure it out.
