Wanted NP205 Short (rear wheel) Shift Rail
MAXMAN
Wenatchee,Washington
Looking for an NP205 rear shift rail in very good shape. The t-case is an 88 round pattern if that matters. Thank you!
Is it a synchro case or no? Does it have a 4WD position switch? There are several versions.
Yours have a groove in it?
I would assume it's a synchro case based on the year, yes it has a switch, and the case I'm assembling was missing that rail.
I have a short rail if you're still looking for one. I have both actually....I just upgraded to JB Fab modified set. You can have both for $50.
