Keep in mind that changing the output in the trans requires tearing the entire transmission apart
Not on a TH400, if I remember correctly.
I don't know why you would want an NP205 anyway, unless you are building a doubler.
Martin
Martin
With the 27 spline output on the 400, I think I'm out of luck for anything even close to bolt-on.
Without running back up thru all the posts, I take it your 400 has the swapped in 27 spline conversion shaft?
If that's the case, just look for any 27 spline 205 that was behind a 350 tranny.
Yeah, the TH400 must have had a 27 spline conversion. Would that be a direct bolt on to certain 205's? Honestly, I'm having a hell of a time wrapping my mind around all the options.
How about snapping a pic of your 400 at the tailshaft end without the t-case so we can see?
It's kind of too late since I already bought the 208 SYE kit, but I didn't think the 241 was significantly stronger than a 208. Why do you see it as an upgrade?
I did keep an eye out for 241 and it's not like they are giving them away.
