Yes I am.. I'll dmI have 1 available if your still looking for it. Scott
Yes I am interested. You have a Picture of the adapter?I have this one…
I think it was from a TH350/205 combo in 1980.
Also have the figure 8 adapter if you’re looking for that as well, but will need some help in confirming that before I could say for sure. Only thing I know is its attached to a 205.
Yeah, I have no way to make one unfortunately...LOTS of those get lost or not re-installed over the years, and keep in mind that each transmission and transfer case has it's own version (different lengths, mostly). They seem to be pretty rare on NP205's.
You could make one easy, if you have metal melting ability.
I have 2 arms 20 each. 1 arm came off 1989 k5 350 700r4 np241 (shorter arm)... the other 1985 k30 th400np205.. (longer arm) not sure if they fit the set up you haveI'm looking for the side torque bar brace to support th350-np205. The one that connects to the bell housing.
I'll posts a screen cap of what bar will work and what it looks like
I'll take both of them...I have 2 arms 20 each. 1 arm came off 1989 k5 350 700r4 np241 (shorter arm)... the other 1985 k30 th400np205.. (longer arm) not sure if they fit the set up you have
IIRC, this was a 1980 350/205 combo figure 8 Adapter.Yes I am interested. You have a Picture of the adapter?
Will this bar work? Right length?
@tarussell
I'm interested for sure I'll dm you.
That is most certainly the correct adapter !I'm interested for sure I'll dm you.
If it truly came from his 80 K/5’s 350/205 set up then you are all set .@tarussell i messaged @76zimmer to make a deal. Hopefully it works out and more so that his torque bar is from this set up in the picture
Does that overall measurement of 34” sound right?If it truly came from his 80 K/5’s 350/205 set up then you are all set .
Hope it works out for ya’ !
The 205 is not installed yet. Is there a way to measure with my 203 that's still in the truck to get an idea of what bar works with the 205? Or is that already what you're suggesting?
the 203 side brace mounting location is further back and therefore will be longer in measurement.The 205 is not installed yet. Is there a way to measure with my 203 that's still in the truck to get an idea of what bar works with the 205? Or is that already what you're suggesting?
