pvfjr
Ok, so I tore out the TH350/203 and put in the SM465/205. I got the driveline lengthened to the proper size, and went to bolt it up. I discovered I don't have the right hardware. The 203 took u-bolts to hold in the joint, and had those little tabs in the yoke that keep the bearing caps from flying out--no clips. This yoke is tapped with 1/4 - 20 threads, and has the perfectly semi-circular spots for where the bearing caps go and there are no tabs to hold them in. I've gone everywhere looking for the right strap kit, and to no avail. Is it possible to switch the yokes from the 203 to the 205? Or would I have to get a u-joint with inside clips? This is the only thing holding me up (from being 2wd at least) and would really like to get it fixed. Especially since my runaround rig just went out on me and now I'm stranded. I also have to get a hub kit and figure out how to get the front driveline hooked up. 203 had a flange for the CV, 205 has a yoke. But I'll worry about that later. I would really appreciate any help.
