GonicGM
This aftermarket adapter is used to swap a TH350 onto an application that originally had a TH700r4/NP208. In this application, an OEM 81+ TH350 4wd trans. or a 2wd TH350 is used without tailcone (obviously) with tailshaft cut. Spacer goes between TH350 and Stock TH700R4 adapter. This makes total tranny/transfer case length correct for crossmember and OEM driveshaft length as the TH350 has a shorter case. $45 + Ship
