think_07
Registered Member
I just picked up a SM465 and with it came two NP208 transfer cases. I will be swapping the 465 into my K5, but am not sure if I should keep my stock 208 (from a 700r4) or use the one of the ones the guy gave me. He swapped the back halves of the 208C with a 208D to remove the sliding yoke, so now I would need to build a driveshaft with a CV joint in it. What should I do? What CV joint should I look for to make this work if I keep the 208D tcase? Thanks a bunch. I can provide pics if needed.
